Inventor Forum
Inventor HSM
2 REPLIES 2
254 Views, 2 Replies
Inventor HSM
I am working with Inventor HSM creating a tool path and posting gcode to use on a lathe. I am having trouble with the radial dimensions posting incorrectly. I believe it might be posting the dimensions as a radius instead of a diameter. When a cylinder that may be drawn within inventor to 3in. in diameter is appearing in the code 1.5. When I bring that code to my machine, it doesn't read that correctly because it is thinking that that is the diameter. Can you help me with this?
Brandon
2 REPLIES 2
JDMather
Try posting your question here https://camforum.autodesk.com/
in reply to: JDMather
I will. Thanks
