I am working with Inventor HSM creating a tool path and posting gcode to use on a lathe. I am having trouble with the radial dimensions posting incorrectly. I believe it might be posting the dimensions as a radius instead of a diameter. When a cylinder that may be drawn within inventor to 3in. in diameter is appearing in the code 1.5. When I bring that code to my machine, it doesn't read that correctly because it is thinking that that is the diameter. Can you help me with this?
Brandon
Try posting your question here https://camforum.autodesk.com/
