Hello!
I exported the .obj file but Inventor does not export the name of the applied materials.
When I import the .obj in 3dsMax the material name is the RGB number.
I did a test with .fbx and the material is also named with the RGB number.
I would like to export the .obj or .fbx with the name of the materials applied in Inventor.
Can someone help me?
Solved by johnsonshiue. Go to Solution.
Hi! This is a limitation. Inventor Obj Export workflow does not allow material style or appearance style to be exported. Only geometry is exported.
Many thanks!
