Inventor Help Modeling Bent Metal Part With Angled Tabs
https://en.calameo.com/read/003053497ca8a95ec4d90
I have no idea on how to do this can anyone help me. Thank You!
kelly.young has edited your subject line for clarity: Help me please with this
By this I mean how to make that 3D object on inventor
TheCADWhisperer
Can you Attach the *.ipt file of your attempt here?
This is all i have so far if i have the base of the design then i should be fine with the rest im just confused on the base of the design
TheCADWhisperer
@Anonymouswrote:
... then i should be fine with the rest ...
The do the rest of the part first.
You will not need any Splines to create the part.
Can you ask your instructor to join this discussion.
Forget the geometry to left side of image - and model this simple geometry first.
Attach your new attempt here.
TheCADWhisperer
The dimensions are hard to read in your original image and it appears that these Radii dimensions are missing.
I assumed that the inside bend radius was 20mm.
Im still working on the geometry on top but heres the attempt
