Inventor Frame Analysis Sway
DJFore
DJFore
If i have a tall structure will inventor check the sway of this structure. Im needing to check the stabability of a platform and find where I need to add bracing. If this is possible does anyone no a good resource.
I am using INV 2012 Professional (Product Design Suite)
henderh
Hi djf,
  If you're referring to using Frame Analysis in AIP, it doesn't have any time-dependent functionality, or take into account wind shear or seismic loading.  It is for static stress only.
  Autodesk Robot Structural has these, and Autodesk Mechanical Simulation can handle many of these types of cases.  You can download free trial versions:
Hugh Henderson
QA Engineer (Fusion Simulation)
