Inventor filling wrong drive
Hi, I have been running Inventor 2015 on my computer for FEA recently and It has been filling up my C drive despite beinginstalled on my D drive. I have a 128GB SSD for C so I wanted to reserve that for the OS and Office; and i have a 1TB HDD that i have installed programs on. there is plenty ofspace left over on D. I had noticed over the last few days that the remaining space on my C drive has dropped by about 20GB and I havent run anything other than Inventor.
The RAM usage has been up for 13-14 gig (of 16). I have been doing some fairly intensive FEA work with 6-7hr solve times.
Basically, does anyone know why my SSD is filling up? And if it is inventor, is there a way to set the location for all this data to be on my HDD?
Many thanks
swalton
It looks like you installed IV on D:.
Where are you saving your IV design files?  By default, they are somewhere in the My Documents folder, which is usually on C:.
I have simulations that generate 500 MB of results data that only ran for 1.5 hrs.  IV stores the FEA results in a sub-folder below the source iam/ipt.  If your IV part/assemblies are stored on c: then you could very easily eat up drive space with FEA results.
Have you cleaned out your temp directories?
Steve Walton
Inventor 2025
Vault Professional 2025
rhasell
Hi
Not sure if this is applicable, but have you checked your temp folder? It is normally hidden so deep. it almost impossible to mange.
Step one: Create a Temp folder on your C: drive (OR D, its up to you, I figure that the OS want a fster drive for temp files)
Step Two:
Right Mouse Button on "Computer", select "Properties".
Select "Advanced System settings"
Click on "Environment Variables"
- Take note of the directories, this is where your temp folder is currently located.
- These files can be deleted, (That is if Explorer will let you, IMO useless file manager)
Step Three:
Change the Existing temp locations to the newly created temp directory.
This will allow you to view and manage it a lot easier than before.
Worth a try.
Reg
2026.1
Paul-Mason
When you cretaed you project,ipt, file did you specify the D drive.
Shows up and work perfectly for me.
Have you tried recreating the IPT file to the D drive?
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
