Inventor: Exporting drawing into PDF
Dear All!
I have a problem regarding exporting .idw into PDF format. When I use the regular line weight settings the drawing in pdf is usually not so good, the lines are too thick and sometimes I can not see the details of a View.
If I click on the "Remove object line weights" then it's better, but with this all of the lines are the same. That's also not good.
I think there is a problem with exporting because 0,7 mm line thickness is considered as normal according to the standard.
Attached photos,
Thanks for the help,
Benjamin
sergio.bertino has edited your subject line (Exporting drawing into PDF) and has embedded your images for clarity.
Sergio Bertino
