Inventor error
Inventor error
hamed_nemati
Inventor error
hamed_nemati
I just started getting this inventor error when i save a part, ass'y or
drawing. Any idea's?
The error reads: "The filename, directory name, or volume label syntax is
incorrect"
JDMather
incorrect"
What are the File name, the Directory name and Path?
Are you using Projects (*.ipj) or are you using Vault?
Gabriel_Watson
Check if your file name or folder path where the file is in has non-ASCII symbols and/or Cyrillic alphabet letters, for example, then remove those and try again.
hamed_nemati
Yes i use  *.ipj
Frederick_Law
Is that network drive?
Cloud?
USB drive?
What is the filename you try to save?
Folder name?
johnsonshiue
Hi! Does the total file path including the file name exceed 256 characters?
Many thanks!
Software Test Engineer
