Inventor Dynamic Simulation Timestep Problem in Output Grapher
emimo18
emimo18
When my simulation has finished Inventor changes my timestep to 0 and i get a flat line in the output grapher. The problem is described below.
Step 1: I run my simulation and the grapher starts ouputting the stroke of the cylinder vs time.
Step 2: Everything is running smoothly and data is being logged and plot looks as expected.
Step 3 (Bug occurs): Data logging has finished and everyhting is messed up. The Timestep barely changes and thus the stroke wont change either.
Why does this happen and how do i fix it? I have linked an assembly with the simulation of the robot arm.
emimo18
I should note that i tested the same simulation on my laptop and got the desired results.
