Inventor Dynamic simulation_Table tipping test
Hao.NguyenCongVu
Hao.NguyenCongVu
Hi masters,
Could you help to guide me how to simulate when table tipping using inventor dynamic simulation.
Material: wood; the force would be 57kg
I have attached the ipt file
JDMather
@Hao.NguyenCongVu
Have you tried it yourself?
Where is your assembly with Gravity, Spatial and 2D or 3D Contact Joints?
Hao.NguyenCongVu
hi @JDMather ,
I did the test on inventor, it says Passed (table does not tips) but in actual we found that it failed with very big variance
COG still inside the table
Simulation showed table stable
I have attached the simulation file
Please advise!
JDMather
@Hao.NguyenCongVu
Revolution Joint in combination with 3D Contact does not make logical sense.
The leg immediately intersects into the floor with the Revolution Joint.
Use Spatial instead of Revolution and you could have simply applied a Force rather than adding the 57kg component.
Hao.NguyenCongVu
Thank you very much for your advice
Could you guide me how to insert the right Spatial joint, I tried but its not show the right one
Hao.NguyenCongVu
I did a test3 following your suggestion, the table tipped at 470N, but when test in reality, it tipped at 330N
Please see TEST3.iam in the attachment file
I really need your help
