Inventor Dynamic Simulation Constraints Question
habibhamza753
habibhamza753
I am trying to get a ball to roll down a ditch I made in an inclined plane. I have attached the assembly. What constraints would I need to use to make the ball roll down. I am a novice in this area.
Thank you
JDMather
Spatial Joint and 3D Contact with friction value.  Also Gravity.
Make sure that your ball is not already embedded into the wedge.
Your ball is pretty small - set to Mirco Mechanism Model
