Inventor Drawing View Style Lines Are Very Thin How To Change In Standards?
All my lines are very thin. Can I change this once a view is placed? It might have to do with styles & standards...?
kelly.young has embedded your image and edited your subject line for clarity: View style
Frederick_Law
Are they thin when you print it out?
If it is, you need to set layer style.
If not, there is a setting to Display line thickness in drawing view.
johnsonshiue
Hi! Try this. Go to Tools -> Application Options -> Drawing -> check "Display Line Weight" -> Apply. Is it already checked? If yes, click on Settings -> select "Display True Lineweight."
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous you can change the layer weight and control it from Manage > Styles Editor.
Make sure that the Project is set to Read-Write so that your settings stick.
Please select the Accept as Solution button if a post solves your issue or answers your question.
