Inventor Drawing Change Base View Orientation
Forum
How do I change view of my base before I place so that I can dimension a feature on the other side?
Sorry for the inconvenience.
TIA
Haziq
kelly.young has edited your subject line for clarity: Change drawing view
rhasell
Hi
I tried to find the an informative Help page, but you need to be a Inventor master to understand the help file, so I did not bother.
When you place the view, the view cube is available to change the default orientation of the view.
There is also a Right click option, to change the view to more customised orientation.
You can also edit the view and change the default orientation using the view cube.
Be aware that any dependent views will also update and reflect the change. (You may loose dimensions etc)
There are many ways to show the information, I am just helping you immediate question.
rotate-1.JPGRight click options.Right click options.
Reg
2026.1
S_May
rhasell
That's what I was looking for.
Why can't the good stuff be available from good old "F1- Help" ?
Reg
2026.1
