Inventor Disable Dialogue Associativity For Part Within Assembly
premysl.misun
premysl.misun
if I want (in assembly) some of my parts make invisible than dialogue with remove of associativity is showed.  Is it possible to disable this dialogue for anytime in future in Inventor? I often use visibility and isolation of parts in my work in assembly and this dialogue annoyed me everytime. I don want to use associativity in my projects.
Thank you for your answer.
P.
kelly.young has edited your subject line for clarity: Asociativity
Xun.Zhang
Go to Master view then you are all set.
Hope it helps!
Xun
johnsonshiue
Hi! There is another place you may want to change. Go to Tools -> Application Options -> File -> File Open Options -> Options -> uncheck Associative for Design View.
After that, you will not be prompted if you change visibility of any component. It is because the design view is no longer associative by default.
Many thanks!
Software Test Engineer
