Since I updated to inventor 2020, I can only open inventor once after start up of my laptop. 1st time I load a drawing or part, nothing is wrong, but when I restart inventor it just closes while loading. No error report or what so ever. I thought that maybe i had a bad install, so i reinstalled windows, and installed inventor again, and updated it to inventor 2020.2. Also i updated the autodesk desktop App. The problem still accours.
After i restart my laptop, inventor works until i restart inventor and it crashes again. Someone with the same problem?
Kind Regards, Joël Bos
For now ignore the Autodesk app- it causes more issues that it solves.
If you uninstall, run MSFixit and reinstall as admin using a browser install that will fix any installation related issues.
Your product downloads: http://manage.autodesk.com/
The only other thing I think it could be would be the licenser:
Hi Joel,
This could be licensing related. Please install the following patch and see if it helps.
Many thanks!
Here's the licenser update: https://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-licensing-service-updat...
