- Mute
- Permalink
- Report
Hi Guys,
I've searched the forums for anything on this subject and came up empty, so I'm posting it here as a bug report.
I'm currently using Autodesk Inventor 2025.2.1 - Build 293
The issue - as stated in the Title, is that whenever you delete any file from the home screen when in tile mode it disables mouse-wheel scrolling until another part, assembly or drawing is opened and you must use the side bar to scroll. While this is a minor issue (like the dialog box resize retention issue), it is rather annoying.
Intel(R) Core(TM) i7-7770K CPU @ 3.60GHz
64GB RAM
Windows 10 Professional 64-Bit, Version 22H2 - OS Build 19045.3636
Autodesk Inventor 64-Bit Version 2025.1.2 - Build 241
64GB RAM
Link copied
