Inventor break-out view in Isometric view
virendra_kawadeQQ4E6
Observer Observer
Observer
Observer
Hello All,
I am trying to make a feature visible using break out view (hidden behind flange). Tried to select multiple edges/points, but not able to create break-out view as the "OK' option is greyed out.
Let me know if I am missing any step.
Regards
Virendra.K
RajSchmidt
It should work. But from your screenshot it looks like the break out is missing the boundary profil.
  1. try to pick the circle
  2. check if you have drawn the sketch into the view. (Select the view first, then create the sketch.)
You can also check in the browser. Your sketch needs to be underneath the view, not at the same level.
Observer
Observer
Thank you for the reply @RajSchmidt.
Profile was linked to the view. Upon selecting the breakout view, profile gets highlighted, and I interpreted it as the profile is selected.
After picking the circle, I was able to get the desired result.
