Inventor: Break Out / Section edge - different layer (lineweight)
j.pavlicek
j.pavlicek
is possible to set different layer for edges created by Break Out and Section view?
Same lineweight (thick) as visible edges is confusing. I'm tired from adjusting it manually every time. Basicaly I want to get result in a green circle instead of what is in a red circle.
Same for ends of the section view (now I'm using workaround - crop the section view very near its border to get thin lines on view edges).
sergio.bertino has edited your subject line (Break Out / Section edge - different layer (lineweight)) for clarity.
Inventor 2022, Windows 10 Pro
Sorry for bad English.
Dnyaneshwar_Maid
Yes it is possible to change the default setting of breakout line weight or section edge.
For this you have to go in Manage Tab>>Style Editor>>Object Defaults>>Break Out Line>> Assign Layer which you already defined for desired Line Weight. for your refernce see below Image.
Try similar procedure for section edge, it should be work.
Best regards,
Dnyaneshwar Maid
Dnyaneshwar Maid
Design Engineer @MIBA,
Student Expert@Inventor
Sergio.Bertino
Autodesk Support
Autodesk Support
Hello @j.pavlicek,
Thanks for this interesting post.
When you create a break out, the lines of the sketch you created , prior to creating the break out itself, are converted to visible edges and put by default on the Visible layer.
If you edit the Object Defaults in the Style Editor you should be able to assign a different layer to those edges.
I hope it helps.
Please let us know how it goes
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Sergio Bertino
MFG Technical Support Specialist
