Inventor Assembly resolving
Hello Everyone,
Can someone help me out to resolve following issues:
Q1: I am trying to resolve assemblies i resolve them and save as but after that if i open again same problem occur and has to resolve whole assembly again regardless of i do save as after resolving the file.
Q2: Can I create multiple copies of same part with same drawing name and used them in different assembly. Does it create any problem to load assemblies
Q4: Can I save different sub assembly with different location with same name and use these sub-assemblies into main assembly?
Thank you
Xun.Zhang
Hello @Anonymous,
Have you set up your own project? or Could you try pack and go and centralize all files?
Hope it helps!
Xun
SBix26
All of your questions have to do with Project files, and it sounds as if this is new territory for you.  A Knowledgebase article, About Projects, may be helpful.
I would really recommend that you not have files with identical names.  That creates too many opportunities for mistakes to occur, and makes managing projects a vital part of your work.  Forget to switch projects once and you may mess up weeks worth of work.
Sam B
Inventor Pro 2019.1.2 | Windows 7 SP1
LinkedIn
Thank you
