Inventor Assembly Constraint Cannot Select Plane to Axis
MATTEOALBANESI10971
Observer Observer
MATTEOALBANESI10971
Observer
Observer
is impossible constraint a plane with an axle
kelly.young has edited your subject line for clarity: costraint
JDMather
Attach your assembly here.
JDMather
Try changing your Mate solution options.
MATTEOALBANESI10971
Observer
Observer
I'm sorry, buti I can't send you te assebly. When I try the pack and go appair this message Inventor.JPGhttps://autode.sk/2DTGUbm
JDMather
Only need one *.iam file and 2 *.ipt files involved.
Do you have any "sick" constraints?
If you do a Manage>Rebuild All do you get any error messages?
Can you copy the text from that message into Google Translate to get an English translation?
MATTEOALBANESI10971
Observer
Observer
I don't understand what's happenig. Usually, when I have constrain problem at first I made a rebuild, then I check for sick constrain and if I don't find the solution I close and re-open the assembly or, at least, shut down and restart Inventor or even the pc. Yesterday I untill repair Inventor through Windows App Impostation but the problem persist this morning. Now is all right.
MATTEOALBANESI10971
Observer
Observer
Is possible then the problem i caused by graphic card setting or dirver?
