Inventor Assembly connecting parts to two sides of a coil
Hi
I am completely new with inventor. For a school work, I need to connect two parts to two sides of a pipe I made with coil command. I use Joint command and for the beggining of the coil it connects the part perfectly, but at the end of the coil it does not do it. Any idea on how to do it? It made me really frustreighted.
I will attach the assembly file here, in the case you can help me with some hint it will be really appreciated.
Thanks. Saeed
you need to use "pack-n-go" (right click) on the assy in order to upload it so others can see.
mdavis22569
You need to include the ipt's for the IAM ...
I wouldn't do the pack and go ..that will provide way to much info for this question
Mike Davis
Hi
Thanks for your help. I managed to attach the parts using the constrains. I was not around for several days and it made a delay in responding.
Saeed
