Inventor 2026 – “Format Text” window appears blank in multi-monitor setup (SOLVED)
marcomoretto83
Message 1 of 1
marcomoretto83
Hi everyone,
I’d like to share an issue I ran into with Inventor 2026, which cost me some time, and how I fixed it. Hopefully this helps others facing the same problem.
🔎 Symptom
  • The “Format Text” dialog opened completely blank/white, without any buttons or content.
  • The issue only happened when using a dual-monitor setup, and only on one of the screens.
💡 Diagnosis
After some testing I noticed:
  • If I opened the window on the right monitor → it stayed blank.
  • If I moved it to the left monitor, closed it, and reopened it → it worked correctly.
So the problem wasn’t with Inventor’s configuration files but with how the graphics drivers handled multi-monitor rendering.
🛠 Solution
The issue was caused by my NVIDIA Quadro RTX 4000 drivers.
Here’s how I solved it:
  1. Downloaded the latest drivers for my GPU from NVIDIA’s website.
  2. Launched the installer and chose Clean Installation.
  3. Restarted the PC.
Result
  • The Format Text window now opens correctly on both monitors.
  • The issue was related to the graphics drivers in a multi-monitor setup, not to Inventor or the user profile.
👉 Tip: If you run into similar blank/empty dialog issues in Inventor on a dual-monitor setup, try reinstalling your GPU drivers with the clean installation option first.
Replies (0)
