Inventor 2025 - Student // Crashing and ending with no crash report
FS!
FS!
Hello!
My inventor 2025 (Student) simply crashes and close without any error report.
What can I do or check? 😞
FS!
johnsonshiue
Hi! Please make sure all critical Windows updates are installed and the graphics driver is updated. Also install 2025.2 update and clean up %temp%. Go to Windows Display settings and select the recommended resolution and scale. Right-click on Inventor desktop icon -> Properties -> Compatibility -> Change High DPI settings -> check both boxes.
If nothing above helps, try adding "INV_ENABLE_WER_SUPPORT" environment variable and set it to 1 (Control Panel -> System -> Advanced System Settings -> Environment variables). You should see a crash dialog. Submit the crash report and send me an email
Many thanks!
Software Test Engineer
