Inventor 2025 - Sketch Shortcut Bar \ Section View Action Bar
- Mute
- Permalink
- Report
Hi, were having a weird thing here happening with multiple machines, and setups.
I have tried searching for this problem but can't seem to find anything conclusive.
When your in a sketch,
klick on a surface the ''shortcut bar'' appears, making you able to klick:
edit feature, edit sketch, share sketch, make sketch visible, create sketch, create finish...
But if I'm zoomed a little out so that i can see the whole part, this shortcut always appear to the left side of the screen and ain't responsive. cant click on anything.
(A thing to note here is that the browser bar that you see on the left side of the picture here is on another screen)
I need to zoom into the part and then klick the surface again to be able to klick on the shortcut bar.
Then it appear more or less where the mouse cursor is.
But here's the kicker!
Sometimes it works just fine also, i can be zoomed out and seeing the whole part clicking the surface ant the shortcut bar appears with no problems.
I clicked off surface and on surface 4 times here and on the 5 time the shortcut bar jumped to the left side and became unresponsive.
This glitch or bug is not only limited to the sketch, it I'm in an assembly\part and to use the section view. it acts the same way.
And if i zoom into the part (like way close) i am able to get it working after klikking it a couple of times.
Setup:
Multi Screen - 4x
Running inventor on one of the secondary screens. (Screen 2)
Having the browser bar and ilogic browser on primary monitor. (Screen 1)
Hope someone has a quick fix for this!🙄
