Inventor 2025 flange offset is not an option anymore.
G.vd.lisdonk
G.vd.lisdonk
Hey all,
3 weeks ago i updated all 5 of our workstations to Inventor 2025.
After some struggles i got everything installed propperly.
Since then, my 4 coworkers have been using it without any issue.
Today i came back from a 1.5 week long work trip.
Now, when i want to add an offset flange the option does not show op on my station.
My other coworkers can select it just fine.
I dont know if this allready was the case 3 weeks ago because i did not really model anything new.
see some added pictures for clarification.
Replies (8)
James_Willo
Hi, Please update to 2025.1, this is a new feature.
James W
Inventor UX Designer
G.vd.lisdonk
I forgot to add, i updated yesterday. one of my coworkers wo has not updated yet has acces to this feature.
James_Willo
You're referring to the 4th icon right?
That's strange, the help documentation says this is only in dot 1.
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-0A690154-4556-46A6-A69E-5005A7F8CB51
James W
G.vd.lisdonk
i think it says you can now drag the offset, it does not say the entire ofsett tool is added.
CCarreiras
Hi!
Try to reset your Inventor using INVENTOR RESET UTILITY:
CCarreiras
James_Willo
Sorry, I clearly didn't read that properly!!
Please try moving your cursor to the edge of the panel and dragging it bigger. It seems that at smaller sizes the 4th icon disappears.
James W
G.vd.lisdonk
Thanks, this helped.
maybe make it so it drops down when the window is to narrow.
happy it was an easy fix!
James_Willo
I've brought it to the attention of my team members. We truncate the text with ... but currently do nothing for icons. We should think about this. Thanks for reporting!
James W
