Inventor 2025 Bolt Connection With Empty List or hardware
snguyenSWVMS
snguyenSWVMS
Hi All
I need help to fix this problem with bolt connection with an empty list hardware.
I found this same problem in Autodesk with the solution but I try those step and mine is not working yet.
I am using the bolt connection since it came out with Inventor and this is the 1st time I ran in this problem.
The bolt connection has no hardware and if I try to use the manual way goes thru the Content Center and all the hardware there and I can place them in the assembly. If I use the AutoDrop then after I selected the hole it has the bolt connection feature so I use that and it pop up the bolt connection and everything work from there, I can also save the set of bolt in the template.
But if I use  the bolt connection then I see just an empty list.
Any idea please help me out.
snguyenSWVMS_0-1757937103130.pngsnguyenSWVMS_1-1757937118123.pngsnguyenSWVMS_2-1757937130435.pngsnguyenSWVMS_3-1757937155767.pngsnguyenSWVMS_4-1757937203067.png
kacper.suchomski
Hi
I vaguely remember that reselecting the directory sometimes helps.
But you'll probably get better help if you provide the exact version and update of your Inventor.
Kacper Suchomski
snguyenSWVMS
Kacper,
I think I know what I did wrong here but still working on the fix way.
After vault console installed (ADMS 2026) I attached all the (11) standard content library to vault console, then from there I created a content library read & write then I use content editor in Inventor to copy each family of hardware or anything I need for my read & write library. Because manually copy I think I didn't copy everything.
So I am still looking the faster way to change the Autodesk content library to new custom content read & write library.
I post the question on Vault Forum
