Inventor 2024, what happened to 'hole preview'?
dwiSHLMX
Message 1 of 8
dwiSHLMX
Fumbling my way through our recent update from 22 to 24'.....
Realizing that now 'hole preview' is gone?  Inventor used to 'auto-project' the geometry onto your part, before actual command execution. There was a little check box to turn it on/off.
Can anyone confirm this? Or has some mundane setting been changed/moved I'm not aware about.
Thanks!!
Replies (7)
Message 2 of 8
Gabriel_Watson
Is this at the Part or Assembly environment?
See if these are set for you:
Message 3 of 8
dwiSHLMX
I am working with a weldment assembly.
All settings are the same as yours; 'cross part geometry projection' check boxes are both checked. Same with autoproject and sketch origin.  Appreciate the help and great pics!!
Anyone else?
Has Autodesk just eliminated this feature, thinking the utility was just a hassle for people with weak graphics/hardware?
Message 4 of 8
johnsonshiue
Hi! Are you talking about Bolted Connection? Or it is the regular Hole feature?
Many thanks!
Software Test Engineer
Message 5 of 8
dwiSHLMX
No 'bolted connection'. Regular hole feature...
Message 6 of 8
JDMather
@dwiSHLMX
Can you Attach assembly (or dummy assembly) that exhibits this behavior?
Can you include screenshot of what you see on your machine Shift Win S and Ctrl v in a Reply...
Message 7 of 8
dwiSHLMX
Appreciate the response! OK here goes:
Problem looks exactly as you've shown: hole command activated, but all we're seeing is a wireframe projection, NOT a preview of what it looks like, actually breaking the surface of the model.
Message 8 of 8
johnsonshiue
Hi! Unfortunately, that is how the hole feature preview looks like at the assembly level.
Many thanks!
