Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Inventor 2024 iLogic Error during start
stigler
stigler
Hi out there!
I have installed Inventor 2024 (in the same way I have installed all the other releases before) - but when I start the software I get the following Error message:
after pressing the "OK" key Inventor 2024 starts normally and I can work with all the templates.
But as I  could not find the iLogic tools I went to this tool to control if the iLogic module was loaded correctly during start.
Even when I load this iLogic Environment I cannot find the iLogic icons!
When I start the Inventor new (with Automatic Loading iLogic) the same procedure as before.
Do You have an idea how o fix this?
Thank You
MjDeck
 Can you share the .ipj file for your active Inventor project?
If you don't want to post it publicly, please send me a message on this forum and I can send you my email.
If you have more than one project, please try activating a different project. Or create a new one. Then restart Inventor.
Mike Deck
Software Developer
Autodesk, Inc.
stigler
Hello MjDeck!
The Project file was the hit I needed to solve my problem!
The newly installed Inventor did not start in an active project! Normaly this should be "Default".
I created an own project and everything worked fine!
Thank you for the hint, have a nice Easter Time
Stigler
