Inventor 2024, Export Inventor drawing as dxf
kasper
kasper
Hi
Inventor 2024.
Where do I find the option for saving an Inventor drawing as a dxf-file?
I can choose the option to save as a dwg-file in different AutoCAD-versions, but I cant choose to Save or Export as dxf-file. In the previous versions I didn't have the problem.
Best regards
A_Gerner
No idea if this is correct or not, but don't you want the DXF to be made out of a face and not an drawing which contains multiple lines etc. which you don't need in the DXF file?
For making a DXF file from a face you have to be in the part and right click and click on 'Export Face As...'.
kasper
My subsupplier needs dxf-files of 2D-drawings.
kasper
A reinstall was the solution. Now the problem is gone.
