when using iCopy combined with an assembly that is created through the top-down method, it fails to place it according to the user input ( I have two versions of this, one that is parametric, and the second one that has a fully unconstrained layout for geometric placement and both fail)
all files are attached.
I also have another example with a bottom-up assembly that includes some iLogic rules, the placement works flawlessly, however, none of the rules run automatically, you need to open each iCopy instance and force the rules to run, I haven't tried with external rules yet. if anyone can share their experience with this would be great, I should probably create another post for the iLogic one if need be.
iCopy-Parametric Failure.mp4 - TechSmith Screencast - TechSmith Screencast
iCopy-Geometric Failure.mp4 - TechSmith Screencast - TechSmith Screencast
Ali
