Inventor 2022 not starting up
hEINSTEIN
hEINSTEIN
What could be the issue? neither my IV 2022 and 2023 want to open.
I have checked that the flexnet is enabled, and I have installed the latest updates.
I used IV on friday and I had no issues, it just decided today not to open.
Thank you in advance
Gabriel_Watson
Have you tried resetting Inventor settings on the start menu > Inventor?
Have you tried running as administrator (right-click Inventor.exe, found inside Program Files > Autodesk > Inventor 202X > Bin)?
Have you tried killing any Inventor processes in Task Manager and/or rebooting (probably yes, just checking)?
Have you tried right-click Stop the FlexNet licensing Service and re-launching Inventor (background process inside Task Manager)?
johnsonshiue
Hi! Did you see any dialog or splash screen? Or, Inventor.exe runs but it does not start a session. It could also be licensing related. Please take a look at the following article to reset the license.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Many thanks!
Software Test Engineer
