Inventor 2022 Model States -
davenport_jl
davenport_jl
When I try to suppress a feature in Model States, I received the error message below.
I have no idea of the relevance of suppressing a feature and no help available error message.
I just select okay and keep working.
Autodesk Inventor Professional 2022
No Help available.
Cannot display help page at:
'file:///C:\ProgramData\Autodesk\Inventor 2022\Local Help\en-US\REDIRECT_IDD_SUPPRESS_WARN_FOR_NORMAL_BOM.html'
ID:(Index.html:0), Error 2.
OK
Gabriel_Watson
Install latest updates..... seems like a small glitch that hopefully is fixed in 2022.2.2 by now.
I think your Inventor simply did not retrieve the right prompt text that should come up at this situation. Mine (2022.2) prompts like this when suppressing:
The above "Lean More" link sends you to this location below, and probably this glitch could not find the stored info in your installation directories:
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-9A49CDC1-4DC7-4462-81D7-E18B8339DE0F
I guess you could try to repair your Inventor install, but again, just updating Inventor to the latest patch might be the best path.
Similar issue here:
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Help-...
davenport_jl
Thanks for the quick response.
I am running IV2022.2.2, so no update at the moment.
What I did find is related to the local offline help. If I select the online help, I do not have the issue.
I tried reloading the offline help and still have the same results.
Again, I am not trying to use the help function, the pop up error message is just the result of suppressing a feature.
Thanks again,
