[inventor 2022] Bend notes show wrong angle
mrc4nl
mrc4nl
Hi, i am having a problem with a sheetmetal drawing.  Its an old file that we keep using. Now suddenly when we open the file the displayed bend notes show the wrong angles.  This is not a open/bending angle issue, but completely wrong values.  The strange thing is, that there are no updates pending, and when i place new bend notes, they do display the right values.
I did some digging and it appears to be derived part related. Replacing the derived part or updating it manually causes the drawing to update and show the right values.
I have two sets of files, the current one (wrong values) and previous (right values)
johnsonshiue
Hi! Many thanks for sharing the files! Yes, there is indeed a bug here with the new files. My proof is very simple. Open the new idw file and the part file. Go to Manage -> Rebuild All. Switch back to the drawing. The bend angles will be correct.
When Rebuild All can correct things, it usually means there is a bug. Do you know how to reproduce the behavior from scratch?
Thanks again!
Software Test Engineer
mrc4nl
thanks!
I dont have the steps to reproduce the error.  The part also didn't change much, its usually some iproperties
but i will keep an eye out if this happens again
mrc4nl
It happened again. The strange thing is,everything looks fine when you open the file.  No pending updates, rebuild all is grayed out.  But as soon as a drag the border around, inventor is like hey, do you want to update the document?
and the displayed angles switch location.
johnsonshiue
Hi! I did not see the change in bend angles. But, I did use our internal debug tool to fully migrate the files including the features. Please take a look and see if it works better now.
Many thanks!
