Hello folks.
I am in need of guidance.
I have been building a bracket that incorporates M5-0.8 socket head bolt for the clamp part of the build, and to arrive at the right hole sizes so that the head will be immersed inside the hole and one side of the clamp allows for free insertion of the bolt and the final side on the other end is narrow enough to be tapped. I have made good learning progress by measuring the bolt and specifying a little larger space for it to fit in except for the hole to be tapped which is a little smaller than the bit size the manufacturer specifies.
I am considering integrating a real nut on the other end since it looks like the threading can fail if the bolt get a little too tightly placed. So, I am building a test block with the right size holes in it, including a hole that I believe the hex nut will fit inside. I was playing with the Assembly features of Inventor, brought in my Nut part to include in it and to see if it fits in the hole as I planned. I will bring in a real bolt when I can find one on line or design a part for it myself.
The big question is about aligning the nut with the hole. I have tried Grip Snap position command and am able to bring the bolt into position, but it doesn't stay. I feel like there is a "save" feature somewhere that I can use but I don't see any such feature. When the part is freely moved, it stays in moved position.
I am attaching the models and the assembly to this post for your use and I appreciate your pointing me to a learning source on alignment of Parts in an Assembly.
Thanks a lot.
Farzad
