Inventor 2022.3 - Sketch is giving me two different dimensions for the same geometry.
jeffg28CLY
jeffg28CLY
A screenshot's attached.
I can DM part files only on request.
Running Inventor 2022.3
A reference dimension used in a formula elsewhere in the same part was not updating properly.
The 0.188" reference dimension is from the central plane to the profile edge.
In Sketch, if I try to put another dimension on this same geometry, the dimension preview says 0.178", not 0.188". And when I try to click to place it, rather than creating a reference dimension, Inventor instead says "Sketch dimension already exists."
But if I instead try to place a dimension from the central plane to the profile edge's vertex, then Inventor does not give me an error, and it places a reference dimension of 0.178".
I don't know how I'm getting two different dimensions for the same geometry.
Using the Measure tool on the 3d model, I also get 0.178" for the alleged 0.188" dimension.
The Update button is grayed out.
This issue skewed a dimension and could have caused an intermittent interference fit.
[ The subject line of this post has been edited to include the product name by @CGBenner ]
johnsonshiue
Hi! Please share the problematic file with me directly johnson.shiue@autodesk.com. I would like to understand the sketching behavior better.
Many thanks!
Software Test Engineer
