Hi
Just installed Inventor 2021, and the latest update 2021.3.
I've already adjusted the application options, to fit my needs.
On the "Save" tap, inside Application options. there is a drop-down menu, with choices regarding translation reports.
I set the option to "Do not create translation report".
But Inventor does not care... It creates them anyway.
So I have these 3rd party HTML files, every time I import a non-native CAD file.
It worked in Inventor 2018, which is the version we last used.
Can anyone help to fix this very annoying, non-working application option?
Solved by johnsonshiue. Go to Solution.
Hi! I am on Inventor 2021.3. I tried importing a STEP file with "Do not create translation report." I could not reproduce the behavior. What format did you import? Is it specific to a file?
Many thanks!
Hi
This is kind of weird.
I tried many times yesterday, with several files.
All with the same result. I could not make any translations from any version of step (203, 214, 242) file, without a translation report in the top of the newly created file.
Today, everything is fine.
im sorry to bother the forum, with this.
It must have been a glitch, that disappereared when restarting the computer.
