Inventor 2021 Frame Generator - some questions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I'm trying to help someone with a real project and inventor frame generator could save a lot of time and efforts.
I've been playing a bit with it in the past and now I have some questions which I hope that can be..covered.
1. Which is the best/easiest procedure to follow scheketon outside dimensions for my profiles? So I wish everything inside as can be seen in my attach - going with each line setup individual is the only way?
2. In terms of BOM - in the end my goal is to get individual & total length of my profiles. any tips?
3. Starting with an extrusion and using it as skeleton is a good way to go? If I need to attach another angle for example attached to it.. I need to simply sketch a line on that extrusion and use it as reference?
4. How can I cut horizontal profiles for letting the vertical go through? I've used trim but.. is this a correct result?
Thanks for all your support.
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
