Inventor 2020 stripes/ blurred - graphic issue in Citrix desktop
rattlesnakeNo1
rattlesnakeNo1
one user has an issue with inventor graphic. Its looks like stripes on the screen (please take a look on attached picture).
On our tests:
other Client-PC, other Displays 27", other Citrix Maschine and same User = ok
other Client-PC, other Displays 27", same Citrix Maschine and same User = stripes on screen
same Client-PC, same Displays 27", other Citrix Maschine and same User = stripes on screen
other Client-PC, other Displays 27", same Citrix Maschine and other User = ok
This issue seems to be nonlinear. Does anyone have experience with the problem? Thanks
It’s not a bug – it’s an undocumented feature
Gabriel_Watson
I do not see stripes in your picture attached, aside from the Sketch center lines. Those can be turned off here:
I would give it a try to have the following setting ON:
Tools > Application Options > Hardware > Software Graphics
Aside from that, from your tests the user is probably OK given the result below:
other Client-PC, other Displays 27", other Citrix Machine and same User = ok
And you have not tested same displays with other PC/Citrix/User, but I would guess this issue is not tied to a monitor/display.
rattlesnakeNo1
Hi Galaxybane,
thanks for your reply. Sorry, yes you are right. I updated the attached picture.
The Option 'Software Graphics' is unfortunately not the solution.
Yes, we have not tested all variants, because the error seems to be an intermittent-error.
Gabriel_Watson
Ok, I guessed this would be more of a Citrix problem than Inventor, and it payed off... I think I found your solution here:
https://support.citrix.com/article/CTX132709
Please let us know if you test and this works. I am attaching the page linked above as a PDF in case their support page goes offline in the future.
This makes sense, as I remember that not only Inventor but other applications come out strange because of the graphic compression Citrix uses. I used to work in a school where other applications would look quite different through Citrix (usually ok for accounting/finance users, but us CAD designers get more bugged with that).
rattlesnakeNo1
@Gabriel_Watson  Thanks for that great tip, but unfortunately  this wasn't the solution.
I agree to you that it looks like an citrix issue. In the past we never had this issue with our fatclients (no citrix environment).
Okay, if I figure it out, I will post solution here.
