Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I have problem with installing inventor. I am using student licence. Although I download the program, there is an error. how can fix this?
First I installed autocad and then I tried to install inventor.
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
You spend the time to cross out your user name in the image but never did anything regarding the assigned student serial # in the image. Make sure to blur out all sensitive info since this is a world wide public user forum. I will have the moderator remove or blur out your info.
In addition installation of Autodesk product needs to be posted in the installation and licensing forum https://forums.autodesk.com/t5/installation-licensing/bd-p/24 for best results. I will also have the moderator relocate your posting there.
Now to your issue. 😁
Your issue is related to >>this<<
If that doesn't resolve the issue create a new user account with admin rights and install using that account.
A couple of additional items.
Mark Lancaster
& Autodesk Services MarketPlace Provider
