Inventor 2020.2 update issue
Since installing the 2020.2 update, several users have had issues using embeded spreasheets, whereby the model update function is not available if the spreadsheed is closed after saving changed.
Work around is to save the spreadsheet, update the model then close the spreadsheet.
Also, we use the Design Cloner program.
After update there is an issue where Cloner sees all files as the wrong version of Inventor.
After uninstalling the update, these issues are fixed.
Replies (14)
Xun.Zhang
Hello @Anonymous,
Yes, we made an enhancement in this area to improve the performance. The key here more like no Update needed if there is no value changed in the spreadsheet no matter save or not.
Could you help recheck?
Or Could you please send me an example data via xun.zhang@autodesk.com with some description so that we can take a look.
Xun
As mentioned, we have rolled back to the previous version.
Would you like a copy of the file containing the spreadsheet?
Sorry, but I don't fully understand your answer.
johnsonshiue
Hi! The behavior does not sound right to me. I need to work with the project team to understand it better.
Many thanks!
Software Test Engineer
Xun.Zhang
Hello @Anonymous,
For example, you have d0 = 1mm in the spreadsheet link to the parameter and consumed in a feature, open the spreadsheet, make a change to 2mm and back to 1mm, save the spreadsheet, the value is not changed, right?
In this case, no update is need from 2020.2 but request to update in previous release.
In this way, Inventor look into the value to avoid unnecessary update.
From your description, it more like this case.
Please let me know more details in your workflow and a data to illustrate would be better.
Hope it helps!
Xun
LishuangLu
@Anonymous ,
Thanks for reporting! To confirm whether your issue is the same one as we noticed would you please share with us a video and some filest for reviewing?
-Lisa
Please find enclosed links to issue.
2020.1 behaviour: https://autode.sk/37Q62LY
2020.2behaviour https://autode.sk/33tsqaj
Regards
rhasell
Hi
Regarding Design Cloner, I have been emailing the developers and sending messages, but to no avail.
If anyone from Micrographics is reading this, "Please fix the Design Cloner"
Better yet, can Autodesk make one, we don't all have Vault. (Design Cloner is better than all the other provided cloning tools)
Apologies for hijacking your thread.
Reg
2025.2
Xun.Zhang
Hello @Anonymous,
It looks strange to me for 2020.2 one, please send me the excel and the part file via xun.zhang@autodesk.com, we'd like to take a look.
By the way, could you help toggle the Rebuild all to see if it helps or not?
Xun
As mentioned, Cloner works as expected once we rolled back to update 2020.1.
You might want to try that.
rhasell
Hi
Thanks, yes I know that, but I would prefer it if MGFX updated the program instead.
Reg
2025.2
Xun.Zhang
Hello @Anonymous,
Data was well-received, we are checking the problem now.
Xun
IMHO he doesn't need to. It was working fine before the latest IV update. Probably since it's a free add on, he doesn't feel obliged to do anything.
A shame all the same.
LishuangLu
@Anonymous, thanks for sharing the videos! We can understand the issue now, this seems to be a problem related with Embed excel, a bug is being tracked internally, which is INVGEN-35738.
As you said, the workaround is without closing the Embed excel after editting and finish update in inventor first then close the file.
We will investigate how to make a safe fix.
Again thanks very much for your support!
-Lisa
rhasell
Hi
I thought I would update you regarding the "Design Cloner"
I have been in touch with Micrographics, and Autodesk have changed the API, this is causing some issues.  Micrographics are awaiting feedback from Autodesk in order to make changes to the Design Cloner application.
Sadly this does not look like it going to be quick fix.
Reg
2025.2
