I am looking into the export of a number of Inventor iProperties (standard and custom) from assemblies and parts within a project into excel or CSV file. The goal would be to make this an automated process as the design stage moves through various stages. We are looking to use ilogic to aid in the input of standard and custom iProperties.
The end goal is to import the data into a Third Party Data Management software program.
Is iLogic or Vault the best tool to export en masse the required iProperties, from a set up point of view are there Pros & Cons to each option and is one more labour intensive than the other with regards to set up & use?
Appreciate any assistance.
Inventor Professional 2019
Vault Professional 2019
Cheers
Solved by SharkDesign. Go to Solution.
Simplest way to do it is to just open the BOM and click the top left icon to export the iProperties to Excel.
You can do all this in iLogic for sure. You are better off asking in the customisation forum though.
