Inventor 2019: Creating a fillet failed
I'm trying to create a smooth shape. I just want to round the edges of my model.
If I try to use the 'Fillet tool', it says:
   Create fillet feature failed      FilletProblem_MinimalSetup. ipt: Errors occurred during update        Fillet1: Could not build this Fillet          The attempted Fillet operation is too complicated for selected inputs.  Try changing the edges, applying the fillet(s) separately or in a different order, else try a face fillet or a different radius.
I created different versions of my model and also tried with Fusion 360. It showed me a very similiar error. If I go with values below .4 it will work, but I want a different outcome. Do I have to use another tool? Or can anyone please explain why this operation is too complicated and what I need to change?
 I've attached the project file.
Best regards
@Anonymous,
marius.gildehaus has edited your subject line for clarity
Original: Can not use Fillet-tool: Create fillet feature failed
jhackney1972
Please post your file to the forum so others can test and solve your issue.
John Hackney, Retired
marius.gildehaus
Hello @Anonymous!
I see that you are visiting as a new member to the Inventor Forum. Welcome to the Autodesk Community!
In Inventor 2019, I could easily add the fillets to the contour, attached is the dataset.
Maybe you could do a Screencast of the issue, so we can maybe see, what is happening.
Thanks!
Marius Gildehaus
Technical Sales Specialist
Hello @marius.gildehaus,
thanks for your effort and reply. I am able to round the edges within to a value of 3mm. I want to set it to at least 5mm to really get a kind of round shape. I was able to do so at some point before cutting throgh the XZ-extrusion. I also thought about just cutting through XY-dimension but I would have to deal with different sizes at different positions. This seemed to be the easier solution. I've attached the screencast.
Your initial part geometry is far to small for a 2mm fillet. Try applying a 0.2mm fillet and it will work, but this also demonstrates why a 2mm fillet will fail.
murat.aydin1
Community Visitor
Community Visitor
I got same error too. Then realized that I forgot to use tangent for one of 3 arcs that I used for my object. So I think it can be about something related with constrain.
I hope that would be helpful.
