Inventor 2019 Bug: Assembly Section View Cannot See Lines Between Parts
amarcoc
Message 1 of 19
amarcoc
Hi. When making section views in assemblies, I cannot see lines between parts. It seems a whole single part.
How can I fix this?
Check picture in attachment. Black lines delimiting parts is missing.
kelly.young has embedded your image and edited your subject line for clarity: Assembly Section View
Replies (18)
Message 2 of 19
jletcher
Change your view option to shaded with edges
Message 3 of 19
amarcoc
It is. I am a 10 year user. This happened only in 2019
Message 4 of 19
amarcoc
i have also changed hardware options. Tested them all. It could help in some options, but not fix at all.
My graphics is Nvidia.
Message 5 of 19
jletcher
2019 now has default same color for edges you must change it to black.
Message 6 of 19
johnsonshiue
Hi! There was an issue in graphics section view when Texture is off. It has been fixed on 2019.1 update. Have you applied the update?
Many thanks!
Software Test Engineer
Message 7 of 19
jletcher
@johnsonshiueIs it smart to tell users to install a update that has more issues?
35 crashes so far with that update so not sure if I would be selling it.
Message 8 of 19
amarcoc
Yes, I have latest 2019.1 installed.
Bug is present on that version.
Message 9 of 19
amarcoc
Thank you.
Those are the setting I am using. Proof in attachment.
kelly.young has embedded your image for clarity.
Message 10 of 19
johnsonshiue
Hi Marco,
Maybe I misunderstood the issue. Do you have Texture option set to On (View -> Texture)?
Many thanks!
Message 11 of 19
amarcoc
No. I dont use textures. Its a 2019 bug. How can it be reported?
Message 12 of 19
johnsonshiue
Hi! Let me reconfirm with you. It does not really matter if the appearance style has texture or not. After you open the assembly, go to View -> Texture option. Is it on or off? If it is off, please turn it on. Then, do you see a difference in terms of section behavior?
Many thanks!
Message 13 of 19
amarcoc
Hi. Please check attached picture.
You can see the option with textures on / off and the lines missing.
4 computers with different hardware configurations have same problem.
Only thing I see in common, is that they all have nvidia cards.
Message 14 of 19
I sometimes get this if my parts are interfering with eachother? Might be a shot.
Message 15 of 19
amarcoc
It doesnt have interference. It is face 2 face.
Can anyone explain me how I can file a bug report to get Autodesk help? I can log anything as asked.
Message 16 of 19
johnsonshiue
Hi Marco,
Please feel free to contact Autodesk Subscription Support by logging on your Autodesk account to report the issue. In the meantime, I will work with the project team to understand this behavior better.
Many thanks!
Message 17 of 19
johnsonshiue
Hi Marco,
I have contacted the project team. It looks like a known regression in 2019.1 update. It was reported as INVGEN-16077. It has been fixed internally and the fix is targeted for 2019.2 update
Many thanks!
Message 18 of 19
amarcoc
Thank you!
Can I test that update as beta tester?
Its not released a beta yet, but maybe some other way?
Thanks!
Message 19 of 19
johnsonshiue
Hi Marco,
Sure, you can sign up Inventor Beta program. The latest future release is available for Beta testing. But, I am not sure if the fix is available on that build. Regarding 2019.2 testing, the Beta build is not yet ready. It should be ready within a few months and will be available on Beta site for testing before being released.
Many thanks!
