Hi there,
My first post on here.
Thank you in advance for your time.
95% of the time, tutorials do not load in the tutorial window in Inventor. But sometimes they do, very rarely. Usually the box is either blank or displays this unhelpful message:
"Failed to load URL http://localhost:44441/guided-tutorial-plugin/v2/engine#/play/INVNTOR/2018/ENU/Sketch%20tutorial%201?channel=guided-tutorial-response-channel-000000?mode=enabled?user=Daniel?tutorialLanguage=ENU with error A connection attempt was refused. (-102)."
Context:
This is a brand new instillation of Inventor, as a new user. After noticing the problem, I tried a Autodesk programme (sorry I forgot the name) which resets all Autodesk settings. Later I used the uninstaller tool, and uninstalled all software, and reinstalled. Later I examined firewall settings, ensured they do not conflict. I tried to load the tuts with different wifi connections too. All of which has led me to no solution.
What puzzles me is, one or 2 times, the tutorial did load.
Using this on bootcamp, windows 10.
