Hi! I appreciate your sense of humor. I get it. Inventor LOD is partially mislabeled and partially misused frequently. Every time I start discussing LOD, I always brings up some historical perspective. LOD is a memory management tool enabling 32-bit Inventor to handle large assembly design. On 32-bit Windows, any given application can only use up to 3GB memory. Without ability to unload documents from memory, users would not be able to design large assembly requiring more than 3GB memory.
Some people believe LOD is a configuration tool. I personally do not think it is true. It is because, although an assembly can have unlimited numbers of LOD reps, two or more different LODs cannot be saved simultaneously. Only one LOD state can be saved back to the file at a time. However, each LOD state can be documented as a different drawing view which creates an illusion that each state can be documented independently. This is not true unfortunately. The drawing view does show the assembly geometry in such state. Each view still generates the same PartsList and Mass Prop. This is why I said LOD isn't a configuration tool. It was not designed to be one. Nor would it behave like one.
We are aware of the need to have one assembly representing multiple design intents. In the meantime, you may consider using Design View representation (with visibility filter to override PartsList) instead of LOD for configuration purpose. Design View is limited to managing component visibility and appearance. Changing shape from one rep to another is not yet supported. If you are interested in this discussion, you may want to sign up Inventor Beta (https://bit.ly/InventorBeta) and participate in Alternative Representation discussion.
Many thanks!
Software Test Engineer
