inventor 2018 drawing edit annotation and export
First of all as someone who has been using different CAD software for over 17 years, I want to use this forum to express my disappointment with Autodesk Inventor. I moved from Solidwork To Inventor because I though it would be better and smarter, but I couldn't be more wrong. Inventor is very unstable and anything you want to do is a hassle. The parametric design engine is unbelievably unstable and getting your results out in the form of renders or drawing is horrible. I doubt if the designers of the program are the real users themselves. I can feel that there is a mentality that they know better what is good for the user, instead of just giving them what they need. Autodesk needs to spend more resources on their product otherwise people will move. If you want to stay in the market, please read the forums and if you see people have difficulties with something just change it, instead of justifying. I hope you understand the value of honest criticism.
But the problem I have: I'm trying to get some drawing exported from the CAD design, which I made a mistake making in Inventor. but I can't.
1. when I export into PDF the lines are too thick:
2. In the drawing itself I just can't move the annotation within the drawing. for example the annotation below is in the middle of the drawing, I just can't move it a little bit upwards!
3. To use the drawing in my paper I need to get vector output. I tried using DWG format but no other program is able to open that up. I tried exporting as DXF (not to mention that you have to go save as>save copy as and I don't know of any other program like this. you could just easily put in export or save as!!!! ). unfortunately no other program is able to open the DXF. I tried Inkscape, Illustrator...
