- Mute
- Permalink
- Report
This part I am creating is off of a cardboard scanned pattern I pulled in as a DXF. This is something I have to do often
I need to add a 30° chamfer all the around this part. The black sketch is the depth of the chamfer at 30°. I added the chamfer on the flat in the IPT file to show as reference!
This is a part that will be cut out of plywood on a CNC router and will use the router to cut the 30° angle.
Please advise and thank-you in advance!
