Message 1 of 9
08:47 AM
In the company where I work we have two stations with Inventor 2017. For some weeks now we are facing some situations where the program hangs:
- Resizing the program window, with a file open in it;
- Opening a file inside another (from an assembly, a subassembly or a part; or the origin of a view in an IDW);
- With more than one file open, try to switch between them in the tabs at the bottom of the window;
- Try to open an IPT file.
If the error occurs, it is only possible to close the Inventor process in the task manager. And for some errors, for example opening IPT files, I can only get back to work after restarting the computer.
I tried to find some solution and found nothing like this error. The IT supervisor scanned the two machines and found no update package that might have caused the problem.
Has anyone had a similar problem?
Windows 8.1 & Inventor 2017.4.2
