Inventor 2017 DXF to Inkscape
Message 1 of 32
Hi I am working in Inventor 2017 and I would like to get my files to Inkscape.
When I export a surface from Inventor I get an error box (see picture) ..
If I open the DXF file in RDWorks, and then import it to Inventor I do no longer get the error box but I can not see the file anywhere in Inkscape, it is completely blank..
Please help
Replies (31)
Message 21 of 32
Haha I know xD
I just need to now if it is possible and how before making bigger projects in Inventor, because if it does not work then it would be waste of time 😉
Getting the same error as before with your file.. 😞
Message 22 of 32
mbystry
It not Inventor's fault. Clearly there is something wrong with Inkscape's DXF importer. I don't think it's worked well since the .92 release. There are a number of things that you can do though. I'd recommend exporting/printing your dxf to pdf and bringing that into Inkscape. There is also a free competing 2D CAD application out there (we all know who it is) that will export directly to svg. I use that software as a bridge sometimes for my Inventor to Inkscape work.
Message 23 of 32
WHolzwarth
SVG from Niels is very small.
Here's another one
Walter Holzwarth
Message 24 of 32
It does unfortunately not work I either get some weird looking fat lines or same error as before
Message 25 of 32
Rob67ert
What do you like to do with it in Inkscape?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 26 of 32
Your file works for me!! How did you do it?
Message 27 of 32
I need to cut it in vinyl on a Roland ​CAMM-1 SERVO ​GS-24
Message 28 of 32
Rob67ert
Who do you ask?
Robert
Message 29 of 32
wh
His file worked for me, but I do not know how he made it possible
Message 30 of 32
WHolzwarth
DXF was converted in Rhino to SVG - Vector option.
I tried exports from Rhino to WMF and AI too, but results seem to be worse
Walter Holzwarth
Message 31 of 32
Fair enough, I was hoping for a free solution of the problem but it is good to know Rhino would work for it!
Thank you so much for your time! All of you!!
If anyone has suggestions for a free solution please let me know 😄
Message 32 of 32
WHolzwarth
It depends on what you need: Scalable vector graphics, or raster images.
If a raster image is sufficient, give an export from Inventor to a PNG image a chance.
Walter Holzwarth
