Inventor 2017 - Detail view label is missing
Hi all,
I recently upgraded to Inventor 2017.
I like the new design of interface. However, today I encounter an issue with drawing detail view.
In 2016 when I created a detail view, the view label with scale is always automatically placed above the view. Unfortunately I cannot achieve that in 2017, even if the "Label visibility" is toggled-on.
 Is this a bug in the new version? Or is the command hidden somewhere else?
mdavis22569
works fine for me
Install the hotfix 1 if you haven't yet.
My other suggestion would be to try the inventor reset utility
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Mike Davis
salariua
Two things come to mind.
The view label is there but far outside the sheet: drag the detail view outside the sheet, zoom out and see if anything else moves with your view (might be the label).
Show us the view label text. It might be that the view label is visible but there's no text in it, the view identifier and scale is not there, just empty text. It has been edited and all text removed from it.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Thanks! The label was indeed far outside the sheet...
How do you stop it being thrown off into space? It is very annoying when Rotating a view
